Discussion topic: connection to slave tv
Message posted on 27 Jun 2025 08:07 PM
tv connected by q box failed a few days ago after a number of tv closures, now can't connect 2nd tv by q box. can see digital menu but will not connect
Message posted on 27 Jun 2025 08:14 PM
Re: connection to slave tv
Hi @john575
First reboot the Q box.
Then,
First make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 27 Jun 2025 09:49 PM
What are "TV closures"?
Message posted on 27 Jun 2025 11:30 PM
@john575 Are you sure you're not looking at Freeview rather than the HDMI input the Q box is on?
