6
This discussion topic has been answered Discussion topic: connecting sky q booster with third party router
This message was authored by: SpoilerN9
hi all im havent trouble getting the sky q booster working with my third party router setup. The sky q mini box mini is struggling for signal. the sky engineer set it up but unfortunately the box got reset.
Does anyone have an easy to follow set by step guide?
current setup as follows
Sky q main box wireless to asus router
sky q mini in the other room
sky q booster which has the wifi and power light but the connected light is not showing green.
Re: connecting sky q booster with third party router
Hi @SpoilerN9
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
  1. Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
  2. After a few minutes, the connected light on the booster should  turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
Hi @SpoilerN9
Avatar for SpoilerN9
Level 2 icon
thanks for this
so ive just got the booster working with the Q box
so now im setting up the mini, am i doing mini to booster wps or mini to main sky q wps?
Level 2 icon
nevermind ive fixed it, connected the mini to the booster, all works fine
if only your instructions were on the sky website! thank you
https://www.sky.com/help/articles/sky-wifi-booster-setup-q-booster
Level 2 icon
i read that but thats only with skys own hub. i have a third party router
Yeah, badly worded I think. Same process for both.
edit: oh no it's not, sorry, of course. I used kine to connect the Q to the router so did it that way (which never worked reliably)
