This discussion topic has been answered Discussion topic: connect additional sky q box
Message posted on ‎24 Oct 2023 10:28 PM
I have paid for an extra Sky Q mini box which arrived today. I have managed to connect it to the internet and upgraded the software but the screen says "Maximum number of SkyQ mini boxes already in use". I only have a main box, an additional mini box and now this third one. Can't get through to sky and there is no help guide. Any help welcome please.
Message posted on ‎24 Oct 2023 10:32 PM
hi @Mike7471
What is the hardware version of your main box ?
If it is 32Cxxx then you have an older 1TB non-UHD Box which can only support 1 mini box
hi @Mike7471
Message posted on ‎24 Oct 2023 10:37 PM
Re: connect additional sky q box
Thanks for the fast reply. Sadly, it's a 32C :-(. Such a pity Sky does not tell you that when you order from them. I assume I now need to upgrade the hardware or out the other in standby mode when I want to use the 3rd one? Thanks again for your help!
Message posted on ‎24 Oct 2023 10:39 PM
hi @Mike7471
yes, unfortunately they charge for an upgrade.
BTW All other main boxes still only support a max of 2 active minis
Message posted on ‎24 Oct 2023 11:20 PM
Where do I go to find a link to buy an upgrade to the 2TB box to allow me to use two Mini Q boxes?
Message posted on ‎25 Oct 2023 06:51 AM
hi @Mike7471
Unfortunately the online (on box/web etc.) links were removed a couple of years or so ago when there was a shoratge of 2TB HDR boxes and have never been re-instated.
Thus you will need to call. If you need a number then:
If you have the MY SKY app I think you may be able to find a number there - especially if you are a SKY VIP member
If not go this page & scroll to the bottom and expand the link need more help & scroll down
https://www.sky.com/help/home
If you have SKY Mobile or SKY Talk land line then I think you can also call 150
