Discussion topic: changing to sky q
Message posted on 02 Sep 2024 01:59 PM
changing to sky q
Sky want me to change over to sky q from sky+ will i get a new viewing card
Message posted on 02 Sep 2024 02:04 PM
Re: changing to sky q
@Tinakelly yes you will
Message posted on 02 Sep 2024 02:06 PM - last edited: 02 Sep 2024 02:07 PM
hi @Tinakelly
I am not sure - I think some SKY HD cards are compatible and just get upgraded
You may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
BTW Just because SKY would like you to change over it doesn't mean you have to unless there is some specific reason you need to
Message posted on 02 Sep 2024 04:37 PM
@Tinakelly if your card starts with a 7 or above then it should be fine
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
