Discussion topic: I have a regular repetitive bleep from my sky Q box
This message was authored by: Justinmcj
It doesn't happen all the time, but becoming more frequent and can be heard coming from the unit itself loud enough to hear over the TV sound. Anyone have any ideas?
Re: I have a regular repetitive bleep from my sky Q box
@Justinmcj press the home button on your remote scroll down to settings then goto accessibility check to see if beep on audio description shows on or off if on change to off
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Justin13
Thank you for your reply. I have checked settings as recommended, but beep is off.
Any other ideas?
For example, this evening it's happened for the past two hours and then as I post here it seems to stop (scratching my head).
Any other ideas?
@Justin13 do you have a voice remote ?  as the only other thing I can think off is the remote, you could try pressing the middle button on the Q box the one that has the blue Q when playing recordings this should send a signal to your remote and start it beeping so you can find it if its the same noise that you hear then its the remote
not sure why it would beep unless its faulty but worth checking to see if its the same beeping noise that you are hearing
This message was authored by: hocka
Did you find a solution to this please? I am having the same problem. Mine makes around 5 beeps every 10 minutes or so. It's just began tonight and it's driving me crazy!
@hocka did you chech out the following
Yes I tried that. I honestly thought it was the Sky box but I have realised it wasn't that after all - it was my hik vision cctv box. I restarted the router and it worked perfectly! No more annoying beeping! Thank you for your reply though x
