This discussion topic has been answered Discussion topic: Sky Q issues
Message posted on
09 Nov 2025
09:38 AM
- last edited:
10 Nov 2025
10:51 AM
by
SpaceSparkie
Technical fault on all channels, going on for months now, Sky saying its my problem not theirs?????
Moderator Actions: Changed title to better reflect issue
Message posted on 09 Nov 2025 03:01 PM - last edited: 09 Nov 2025 03:01 PM
@CarolineBolger wrote:
I live in an apartment block so sky are saying that it's probably someone has latched onto my dish If it's a communal dish then it not your dish and no on would have "latched" onto anything funny though cos when the engineer set me up last year he didn't bring a dish so he must of latched me onto someone else's 🤔 No he connected you to a communal dish and not "latched" onto someone elses
A communal dish is a satellite dish or aerial that serves an entire building or block of flats, eliminating the need for individual dishes on each property. This system, often part of an Integrated Reception System (IRS), provides signals for multiple services like Freeview, Freesat, or Sky to all residents through a single, centralized installation
Message posted on 09 Nov 2025 09:42 AM
Re: **bleep** Off
How full is your hard drive?
Message posted on 09 Nov 2025 09:47 AM
Re: **bleep** Off
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 09 Nov 2025 12:45 PM
Re: **bleep** Off
Thank you. 😊
Message posted on 09 Nov 2025 12:49 PM
Re: **bleep** Off
Hi,
I'm not sure, I'm a bit of a tech nerd lol....
Message posted on 09 Nov 2025 01:21 PM - last edited: 09 Nov 2025 01:22 PM
Re: **bleep** Off
Have they provided an explanation for that?
Q support from Sky, including 'engineer' visits, is still comprehensive even though it's no longer the flagship product.
The only significant exception is where Q hardware is running on a communal satellite signal distribution, which Sky has never supported as far as the dish.
Message posted on 09 Nov 2025 02:39 PM
Re: **bleep** Off
I live in an apartment block so sky are saying that it's probably someone has latched onto my dish, funny though cos when the engineer set me up last year he didn't bring a dish so he must of latched me onto someone else's 🤔
Message posted on 09 Nov 2025 03:03 PM
Re: **bleep** Off
@CarolineBolger Do you have a twin satellite cable feed emerging through the outside wall of your flat, or do you have a single cable connecting your Sky Q receiver to a wall mounted communal faceplate which is usually on an inner wall.
Godfrey.
Message posted on 09 Nov 2025 03:09 PM - last edited: 09 Nov 2025 04:16 PM
Re: **bleep** Off
If your Q box is using a communal satellite signal distribution system then unfortunately Sky are correct in denying responsibility for reception issues: that's the remit of whoever the building management has contracted to maintain the system (and is the most likely explanation for your prolonged issues)
Message posted on 09 Nov 2025 04:20 PM
Re: **bleep** Off
Yes you're probably right, back to fivber for me so, even the weather affects the dish, never again,
Thanks for explaining it to me 😀
Message posted on 09 Nov 2025 04:32 PM - last edited: 09 Nov 2025 04:46 PM
Re: **bleep** Off
@CarolineBolger To confirm whether you are being fed from a communal IRS distribution, in order to allow us to provide accurate advice on what course of action is required to restore your Sky Q reception.
Does the satellite transponder signal connected to your Sky Q receiver use ONE or TWO coaxial cables.
Because, if a communal satellite dish is correctly installed and maintained, only a very heavy local cloudburst should effect your reception, and then for just a few minutes, once or twice a year.
Godfrey.
