3
This discussion topic has been answered Discussion topic: Sky Multiroom
This message was authored by: yatesstace
Sky Multiroom
Hi guys, I see multiscreen is on an offer for Black Friday and was going to take up this deal as just got a new tv for the bedroom.
Upon clicking the button to go ahead I stopped myself as it said it was removing my sky go extra I have?
Is this right? I would still want my sky go for when I am at work, on the go etc
How do I approach this?
Stacy/Ross
This message was authored by: SKY1992bf Answer
Re: Sky Multiroom
Sky multi room includes sky go extra as standard so you won't lose out
it's basically removing it and re adding it
note if you currently have sky go extra free any changes made mean you won't be able to re add the free version in the future as it no longer exists as an option
Re: Sky Multiroom
Avatar for yatesstace
Level 2 icon
Re: Sky Multiroom
Ok thank you for your reply
So basically I can go ahead and not worry about the fact it says it's dropping off?
I assume I keep using sky go as normal?
Re: Sky Multiroom
@yatesstace  yes you can go ahead without worrying and continue to use sky go as normal
