Discussion topic: Viewing card
Message posted on 09 Nov 2025 02:29 PM
Viewing card
Cannot view recordings. Message on screen 'Please insert viewing card chip upwards' have done this to no avail. Have followed instructions on 'Settings' etc but viewing card number does not show. Have rebooted my router and switched Television off for a couple of minutes then followed screen instructions- still same message when I select recordings ie Please insert viewing card........etc. Have also carefully dusted viewing card with soft cloth. Am at a loss, can anybody suggest anything else?
Message posted on 09 Nov 2025 02:39 PM
Re: Viewing card
@Barabel Your post has been moved from the accessibility board as your issue has nothing to do with Sky's Accessibility services.
Which box are you using Sky+HD or Sky Q?
Message posted on 09 Nov 2025 02:44 PM
Re: Viewing card
I am using SkyQ, thank you, should have provided that information
