2
This discussion topic has been answered Discussion topic: bedroom TV dropped connection to sky, will not reconnect
This message was authored by: Claymores
been watching TV via WiFi in bedroom for a year and half , has dropped a couple of times but always reconnected , this time we've tried normal procedure but bedroom box cannot reconnect to skyq ?
can anyone help ?
Re: bedroom TV dropped connection to sky, will not reconnect
can anyone help ?
Hi @Claymores
Try completly resetting the mini.
Reboot the mini as above.
can anyone help ?
Hi @Claymores
Avatar for Claymores
thank you , did not work , i'll have to get in touch with sky
