Discussion topic: apps on sky tv won’t work
Message posted on 25 Jun 2023 05:27 PM
Hi can anyone help please of recent our sky tv box kept going onto silent when we used youtube,netflix etc now all the apps have stopped working including some of our bought items
Message posted on 25 Jun 2023 06:34 PM
Re: apps on sky tv won’t work
Hi @nigel1972.
