Discussion topic: Issues with picture for 3 days
Message posted on 25 Jun 2023 06:40 PM
My picture has been pixelated for the past 3 days
Message posted on 25 Jun 2023 06:43 PM
Re: Issues with picture for 3 days
Hi @Glynrobbo
You could
If the issue continues best to contact Sky directly for an Engineer
Message posted on 25 Jun 2023 06:49 PM
I have just done that, and no change. It now says no satellite signal
Message posted on 25 Jun 2023 06:51 PM
It won't show ITV at all and says there is a technical fault.
Message posted on 25 Jun 2023 06:52 PM
Time for an Engineer then @Glynrobbo
