Discussion topic: antenna not working
This message was authored by: Norbert2
antenna not working
getting no reception by sky antenna
Avatar for Norbert2
Level 0 icon
Re: antenna not working
no reception after rain
This message was authored by: Padam_Padam
What signal strength does it say your box is receiving on the settings menu?
Check the connections at the back of the box and if it still doesn't help you'll need to ring Sky and ask for an engineer to attend and check your cabling and dish alignment.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@Norbert2
Presuming you mean the dish, if you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A dish misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
