Discussion topic: aerial
This message was authored by: lorna1231
Message posted on 11 Nov 2023 03:09 PM
aerial
i need to know what wire goes from the tv to the wall as the tv won't work without it. Is it a regular aierial wire
Find out more
Message posted on 11 Nov 2023 03:12 PM
Re: aerial
@lorna1231 wrote:i need to know what wire goes from the tv to the wall as the tv won't work without it. Is it a regular aierial wire
You've posted in a Q forum - aerial (RF) leads no longer apply to them. The Q via the satellite dish provides all channels.
However, if you do have an aerial then you can plug that into your TV and use its tuner. It's a 'standard' RF aerial lead.
