8
This discussion topic has been answered Discussion topic: You tube keeps cutting off
This message was authored by: DeborahFirman1
When kn Youtube app it just cuts off and goes back to tv station. Any ideas how to stop this please?
This message was authored by: iiibizbysa Answer
Re: You tube keeps cutting off
Looks like a firmware update might fix the YouTube issue. Just head to your Sky settings and see if you’re on the latest version (Q270.000.0010.02L). That should do the trick!
What software version are you on? Something sounding like this was fixed in the latest update.
Avatar for DeborahFirman1
I've no idea im a complete technophobe 😂
should i try to reload it?
thank you
No it's a full Sky firmware update needed
look in settings. Current version is pretty intuitive to find.
Thank I'll try that
Version with the fix is Q270.000.0010.02L
if I remember correctly.
Thank you
yes it seems im on that
@DeborahFirman1 wrote:
Thank you
Ok and you are still having the problem?
