Discussion topic: Won’t load programmes waiting for tv schedule
This message was authored by: Kyle10
Tv guide won't load and the likes of the Disney app say try again later but it's been doing this for 2 weeks
Re: Won’t load programmes waiting for tv schedule
Hi @Kyle10
First try a simple reboot.
Failing this
