19
This discussion topic has been answered Discussion topic: Wolf Hall Season 1 episodes missing from On Demand
This message was authored by: Nollaig3
I watched Episode 1 of Wolf Hall Season 1 on Sky On Demand only to find that the rest of the Season 1 episodes are missing...
This message was authored by: PandJ2020 Answer
Re: Wolf Hall Season 1 episodes missing from On Demand
Hit the search button on the remote
scroll to W hit select
move right
click on wolf hall
all episodes are there
This message was authored by: SMartin1
Yes, is there an update on this Sky? Seems
odd to just have the one episode available!
Avatar for Nollaig3
Thanks SMartin1, have you had the same issue?
move right
click on wolf hall
Avatar for Nollaig3
Hi,
I've tried that and only Ep1 of Season 1 amd Season 2 episodes are there.
I'm hoping Sky Support might jump in here and provide a solution.
All episodes show for me.  (I even downloaded S1E2 to check)
I doubt it.  This is primarily a customer helps customer forum and not a route to sky support.
Try rebooting your box and internet router.
Avatar for Nollaig3
Very odd... I'll try rebooting again amd see what happens.
Getting through to Sky Support is a drama in itself. 😞
Tks all
I'm guessing it might be because we are in Ireland? I tried rebooting and still just the one episode from season 1 there.
Avatar for Nollaig3
I'm in contact with Sky Support now Nd they can't explain it either...
They're working on it though.
Avatar for Nollaig3
Fyi. Sky tech team have identified a tech issue and they are working to fix it.
All episodes should be back soon. 🤞
Great, thanks Nollaig
This message was authored by: Oxymoron72
Hi
I'm having exactly the same problem,
Is there a fix??
thanks
Avatar for Nollaig3
Sky said there is a tech issue that they are working on but I've had no further update.
I can only assume they are still working on it....
I was told it wouldn't be fixed for Irish customers.
Avatar for Nollaig3
So we've both been told something different...
When were you in contact with them?
