Discussion topic: Wireless password
Message posted on 17 Apr 2024 10:40 AM
Wireless password
My Sky Q box fails to remember the wireless password. If the box is ever turned off or I lose the wireless I have to reenter the long password ? My wireless is provided by Virgin. Historically I had a Sky router and the Qbox remembered the password. Any advice ?
Message posted on 17 Apr 2024 11:13 AM
Re: Wireless password
@RobL1Is your Q box near your router? Simplist answer if it is, run an etherner cable and that take WiFi out of the picture.
Message posted on 17 Apr 2024 11:29 AM
Thanks for the advice. The router is close, next room 5 m away, but it would be difficult for a cable, "carpet". Cant understand wht it worked fine on my SKY router. ?
Message posted on 17 Apr 2024 11:44 AM
Hi @RobL1
Don't know if it will help but have you split the 2.4 and 5 Ghz bands on the router?
The connection may by more stable if you split the bands and then carry out a network reset on the Q box .
First reset your broadband router after splitting.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
