Discussion topic: Wifi skytv
This message was authored by: Kat1984Allen
Wifi skytv
I can't get apps on my sky tv as it says no wifi ive setting and re starting the wifi but makes no difference
Re: Wifi skytv
Hi @Kat1984Allen
