Discussion topic: Wifi issues on box and remote issues
Message posted on 26 Sep 2023 12:55 PM
Hi my remote for my box has stopped working and my sky box frequently disconnects from my wifi when all other devices in my home are still connected to the wifi
Message posted on 26 Sep 2023 01:12 PM
Re: Wifi issues on box and remote issues
Hi @JWalker10
Assume you are carrying out a Network reset on the Q box exactly as follows.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Regarding your remote issues.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote with the Q box on with Green led.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
