Discussion topic: WiFi on sky q box
This message was authored by: Inders99
WiFi on sky q box
My sky q box has stopped working with sky wifi. It says WiFi not connected, then will reconnect once I press the wps button. But doesn't stay connected for more than a minute or two.
I have tried unplugging the sky q boxes and the sky WiFi. Neither have worked.
Re: WiFi on sky q box
@Inders99 may I ask what colour of router do you have black or white ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Inders99
Hello, it’s white router
Avatar for Inders99
It's a white router.
@Inders99 In that case using the WPS button isn't recommeded. You  eed to treat the white max router as you would a third party router and use the SSID and wifi password to connect your main box to the router.
