Discussion topic: Sky keeps shutting down and we had turn off Power, when turning back on was ok. Now it won’t turn
This message was authored by: skodris
Sky shuts down and we can't turn it on again
Re: Sky keeps shutting down and we had turn off Power, when turning back on was ok. Now it won’t
Hi @skodris
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
