Discussion topic: WiFi and sky box
Message posted on 01 Dec 2025 01:56 PM
WiFi and sky box
Message posted on 01 Dec 2025 02:01 PM
Re: WiFi and sky box
On Sky Q the live television channels arrive over the satellite dish, not broadband.
Message posted on 01 Dec 2025 02:02 PM - last edited: 01 Dec 2025 02:03 PM
@hayley-- A Sky Q box would not be delivered as it would need installing with a satellite dish. Are you sure it's not a Stream puck you have been sent? Check your order confirmation what did you order from Sky?
Can you take a photo of the box and upload it here?
Message posted on 01 Dec 2025 05:36 PM
@hayley-- wrote:
i have just had a sky Q box delivered and my WiFi is not fully working and I carnt use the box because their is no Internet to connect to
@hayley-- are you sure its not the router for your broadband thats been delivered ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
