Discussion topic: WiFi and sky box
This message was authored by: hayley--
WiFi and sky box
i have just had a sky Q box delivered and my WiFi is not fully working and I carnt use the box because their is no Internet to connect to
Re: WiFi and sky box
@hayley--
On Sky Q the live television channels arrive over the satellite dish, not broadband.
@hayley--  A Sky Q box would not be delivered as it would need installing with a satellite dish.  Are you  sure it's not a Stream puck you have been sent?  Check your order confirmation what did you order from Sky?
Can you take a photo of the box and upload it here?
@hayley-- are you sure its not the router for your broadband thats been delivered ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
