Discussion topic: Wi-fi or Harwire to BT Router
This message was authored by: Steve+the+Gooner
Hi All,
I have BT Broadband at the moment. I have hardwired a mini box directly from the router as I was having connectivity issues over wi-fi, unfortunately it appears that the wi-fi overrides the hard wire, does that sound right right.
Any advise is much appreciated.
TIA
Steve
Re: Wi-fi or Harwire to BT Router
@Steve+the+Gooner wrote:
Hi All,
TIA
Steve
hi @Steve+the+Gooner
Is the main box also connected via ethernet to the router ?
When your ISP is not SKY (as you are with BT) then,  if  not this will be an issue as the mini must be connected directly to the Main box or both the main & mini connected via ethernet via the router or an unmanegd switch
Avatar for Steve+the+Gooner
Level 2 icon
Thanks, no the main box is not Harwired! 🙄
