Discussion topic: Wi-fi or Harwire to BT Router
Message posted on 30 Jun 2024 02:23 PM
Hi All,
I have BT Broadband at the moment. I have hardwired a mini box directly from the router as I was having connectivity issues over wi-fi, unfortunately it appears that the wi-fi overrides the hard wire, does that sound right right.
Any advise is much appreciated.
TIA
Steve
Message posted on 30 Jun 2024 02:27 PM
Re: Wi-fi or Harwire to BT Router
@Steve+the+Gooner wrote:
Hi All,
TIA
Steve
Is the main box also connected via ethernet to the router ?
When your ISP is not SKY (as you are with BT) then, if not this will be an issue as the mini must be connected directly to the Main box or both the main & mini connected via ethernet via the router or an unmanegd switch
Message posted on 30 Jun 2024 02:33 PM
Thanks, no the main box is not Harwired! 🙄
