Discussion topic: My two mini boxes not working
This message was authored by: Mickeybell5
My sky mini boxes not working as from yesterday
Re: My two mini boxes not working
Hi @Mickeybell5
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
