Discussion topic: Why does the Sky Q multiroom box need re-initialising every few dats
Message posted on 14 Oct 2024 11:03 AM
My multiroom box in the bedroom keeps losing contact with the main Sky Q box and requests re-initialising every few days.
Can anybody help, please
Message posted on 14 Oct 2024 11:32 AM
Re: Why does the Sky Q multiroom box need re-initialising every few dats
Hi @joymacdel
Reboot the mini as above.
