Discussion topic: Can't watch Sky Witness Recordings
Message posted on 14 Oct 2024 07:25 AM
Ii have an error message that says i need to upgrade the package to watch Sky Witness. This is just for recordings as i can watch the channel. Problem has only occurred in last 2 says. I have tried upgrading software but doesnt fix it.
Message posted on 14 Oct 2024 07:38 AM
Re: Can't watch Sky Witness Recordings
@Bartonbri
You could try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Message posted on 14 Oct 2024 07:56 AM
Thank you for the reply. I have tried that but got the same error message. I followed the instruction to upgrade although I have the signature Package and HD already. I tried to download a new episode and its downloading in SD. So its an HD subscription issue. I will have to call sky.
Message posted on 14 Oct 2024 08:10 AM - last edited: 14 Oct 2024 08:11 AM
hi @Bartonbri
please may I suggest you try changing your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
P.S. You may also need to delete previous downloads
Message posted on 14 Oct 2024 08:14 AM
Thank you for the information. That may be the route I need to take. Just thinking if we have an HD subscription shouldn't we be getting the downloads in HD??
Message posted on 14 Oct 2024 08:19 AM
hi @Bartonbri
yes , if you do have the HD subscription then you should be able to download and watch the HD versions
So, if you have the HD add on you have a different problem
Message posted on 14 Oct 2024 08:37 AM
If you do have the HD add on we can potentially escalate your post to Sky. Sky will then try to refresh the viewing card which sometimes needs a couple of attempts. This link explains more:
https://www.sky.com/help/articles/call-to-upgrade-downloading-on-demand#q-help-articles
Message posted on 14 Oct 2024 08:55 AM
I don't want to set everything to SD as I've just renegotiated the subscription I have We had a conversation about the HD element. I will call to discuss this as I believe I am paying for HD already. I don't want to authorise an online upgrade and find the cost changes.
Message posted on 14 Oct 2024 09:03 AM
In case you don;t know you should be able to see your current subscriptions on your box:
Home - Scroll down to My SKY & select 'Your Products'
You can also see current & future bilss which itemises charges from the same My Sky section
Manage my account - Bills
You will need to enter your PIN to access them
Message posted on 14 Oct 2024 10:45 AM
Ok thanks.
