4
This discussion topic has been answered Discussion topic: Itvbe
This message was authored by: TheoKK
Itvbe
Had itvbe added on extra channels. Had to enter new codes two weeks ago as it was gone. Now today it's gone again and I've tried numerous codes and frequencies but to no avail. Can anyone help?
This message was authored by: nigea99 Answer
Re: Itvbe
@TheoKK wrote:
Thanks for that code but only brings up ITV1 HD and STV HD.
hi @TheoKK
If you have ITVBe listed from before you need to remove it first
Re: Itvbe
Currently on 11386 V 27500 2/3 DVB-S2 8PSK
From the page I use it would indicate it has been there since August
Avatar for TheoKK
Re: Itvbe
Re: Itvbe
hi @TheoKK
Avatar for TheoKK
Re: Itvbe
Thank you so much - that worked.
