Discussion topic: Where's WPS button?
Message posted on 21 Jul 2025 10:27 AM
Re: Where's WPS button?
If you have the new sky hub, it's a tough one to find on this unit.
Hope the red arrow helps here....
Message posted on 12 Oct 2025 01:28 AM
I have the same issue but with a Sky router that is the latest version. The WPS button is on the right hand side. Why do the instructions on Sky do not say this when they say "press and hold the WPS button"?
Message posted on 12 Oct 2025 10:58 AM
Typically because broadband and television are separate bits of the organisation. Incidentally on a Max Hub, holding in the WPS button acts as a reset (which is an incredibly stupid design choice)
