Discussion topic: When trying to watch NetFlix film on my Sky Q mini box an Error code tvq-pb-101(5.6.1) appears.
This message was authored by borneo1964 This message was authored by: borneo1964
I have no problem watching Netflix on my Sky Q box.  NB Amazon prime is OK on the Sky Q mini box just Netflix has a glitch
Re: When trying to watch NetFlix film on my Sky Q mini box an Error code tvq-pb-101(5.6.1) appears.
Hi @borneo1964
Have you tried rebooting your Q boxes.
Reboot the mini as above.
borneo1964
I have re-booted mySky Q mini box  several times but have to admit I have't carried out the procedure on my main Sky Q box.    Might be worth a go later on when She Who Must be Obeyed  has viewed all her soaps.   Have also downloaded software update but no result.    Maybe a replacement mini box is needed?
Many thanks for replying
Software update does nothing if already on the latest version @borneo1964
When you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
borneo1964
Again many thanks ref software updates so next query is would a hardware update be possible.   Apologies for all these questions but in all the years I have been with Sky this is the first problem I have ever encountered
No such thing as a hardware update @borneo1964 .
What I would suggest is a Reset Settings on the main Q box.
Reset Settings in the Q box hidden menu.
if you still have the same issue after a Reset Settings on the main Q box then try a Reset Settings in the mini hidden menu.
borneo1964
@oldfella
have tried what you posted ref main Q box but still nothing so will have to try to contact Sky which probably means an hour in a queue but want this sorted or will cancel NetFlix.   Many thanks for your help ans patience
