Discussion topic: Watching recordings on mini box
This message was authored by: Error+on+minibox
Tried to watch a recording which was still ongoing on my mini box and message kept saying:
the contents you are trying to access cannot be played at this time
I can do this on Sky Q box, does anyone else have same problem?
Re: Watching recordings on mini box
hi @Error+on+minibox
Assuming it's not a UHD recording you should be able to watch it on the mini if it plays on the main box.
Reboot the mini as above.
Avatar for Error+on+minibox
Thank you so much it was UHD so that explains it. Didn't realise this made a difference. Thanks again
@Error+on+minibox
Mini boxes cannot output UHD, and main Q boxes cannot render UHD down to HD (which requires reasonably powerful silicon)
