5
This discussion topic has been answered Discussion topic: Query exchange DPD please?
This message was authored by: 9Y
Hi exchage of equipt. arranged and emails received. Does the original equipment need a sky address. It is in its orig packaging. This wasnt mentioned in the email instructions.  Thank you.
This message was authored by: Dallen9798 Answer
Re: Query exchange DPD please?
@9Y
DPD driver should be able to put a label on it for you, if not I'm sure in the box the new one comes in there is a return label in there you can use.
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
@9Y
@9Y
If you are doing a doorstep exchange of a faulty Sky Q box for a replacement don't forget to remove your viewing card from the old equipment.
@9Y as @Daniel0210 says also if it is a doorstep exchange the DPD should put the old Q box in the packaging the new box came in and put a returns lable on the box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
hi @9Y
It is a straight swap using the same box that the new one comes in ,  so you need to have your box ready. It also requires a return of a remote, power lead & HDMI cable - although you can usually just return the ones that are sent, except if either your old box or new box are a 'V2' box with it's own power supply.
THe DPD driver will have usually a small barcode label they use to return the box  to SKY
As @Daniel0210 mentions,  do make sure you take out the viewing card before sending the old one back
Avatar for 9Y
Many thanks very useful. Y
