12
This discussion topic has been answered Discussion topic: Watching episodes from series link
This message was authored by: Douglas91
Can I watch an episode from a recorded series link without having watched or deleted the previous one?
This message was authored by: nigea99 Answer
Re: Watching episodes from series link
@nigea99 wrote:
@Daniel0210 wrote:
@Douglas91
Also, get into the habit of watching recordings from Most Recent and try to avoid the Continue  option.
Indeed - we do advise the use of the continue Section unless you really know it is pointing to the correct episode
OOPS - were did the NOT go
we do not advise the use of the continue Section unless you really know it is pointing to the correct episode
Short answer is Yes @Douglas91
hi @Douglas91
You don't have to watch in any particular order.
Just go to the series in the Most Recent section of recordings listings and scroll down to the episode you want to watch
The same is the case for anything in catch up or on demand (providing the episode is availble)
P.S. It seems I gave the longer answer 🙂
Avatar for Douglas91
Thanks to you both; that's most encouraging.   What you say doesn't seem to accord with my experience, but I will work through this to see if I can spot where I may have been going wrong.
@Douglas91
Example: you record a weeks worth of Good Morning Britain episodes. For some (strange) reason you decide to watch Thursdays episode first. You can do that without a problem.
Thanks again to you both for your responses and my problem is now solved.
I think the problem arose from my lack of familiarity with the navigation of the Q screen (the box was installed only last week and is of course very different from the HD+ box, which I had been using for about 20 years before!).  After some trial-and-error practice, which is still going on, I think I am beginning to get the hang of it.   I am though still puzzled when I try to delete an episode I have just watched to the end to be told that I cannot do that yet as someone is still watching it!
@Douglas91
You'll get used to it. Most of us were Q newbies once.
My general advice, if you get this is to go back in & then  to make sure you pause it and  then use th e back / dismiss button until back to the Home screen then go back.
I also strongly  advise not to use the buttons above the episode lists as these can often point to the wrpng episodes (e.g. the next episode when near the end of one) but always navigate down to use the buttons underneath the specific episode you want to 'action' (e.g. delete)
@Douglas91
@Daniel0210 wrote:
@Douglas91
@nigea99 wrote:
@Daniel0210 wrote:
@Douglas91
Yes, I had guessed that was a typo!  But thanks again @nigea99  for all your help.
SKY Q can be a bit of a culture shock after SKY HD
If you have any other queries feel free to ask & we will try to help
edit BTW if you haven't already discovered Voice control is very handy & I definitely recommend setting up favourite channels
My favourite voice controls for recordings are :
Skip nn minutes
Go To nn minutes
Back nn minutes
You can use hours, minutes & seconds or mix e.g. Go to 1hour 15 minutes
Skip nn minutes is very handy for adverts and you get used to the length on regular used channels (Many are around the 4 minute mark)
You can also say Go To Start
As I say voice control in general is very useful - see
https://www.sky.com/help/articles/sky-q-voice-control-commands
