Discussion topic: Watch From Start
This message was authored by: Sheila5a
Watch From Start
I have the F1 races on a series link but I cannot Watch From Start if the programme/race is recording.
Re: Watch From Start
Hi @Sheila5a
Are you going to Recordings - Most recent to try to Watch from start?
If it hasn't been watched in any way then Watch from start will not be listed.
You just select the actual Tile and it will start playback from the Start.
Avatar for Sheila5a
Level 0 icon
Hi, thanks - there's some recordings later on today so i'll give that a try.
Hi @Sheila5a
Bear in mind that if the Recording has been watched in any way then there will be the thin blue progress line appearing under the recording Tile.  If you are watching a program and set it to record while you are watching then this will start the blue progress bar on the recording tile.   Likewise if you are channel hopping and visit any channel that is currently recording,  this also activates the progress bar even if you do this inadvertently or very briefly.
Main thing to remember is that any Recordings that are partly watched will always show the blue progress bar and Watch from start tab will then always appear as an option under the recording tile.
Selecting the recording tile itself will start playback from the right hand end of the blue progress (ie at the point previously watched )
