Discussion topic: Walsh
This message was authored by ianwalsh66 This message was authored by: ianwalsh66
Walsh
Cannot get BBC1. Was on phone for 27 mins but got cut off. After many tests which seemed ok now at reset. Do i reset and which of the three ? We were going to arrange an engineer visit but did not get to time and date.
Re: Walsh
Hi @ianwalsh66
Reset Settings in the Q box hidden menu.
