Discussion topic: Picture from sky Q not the same no uhd or hdr
This message was authored by: Harry221
Picture poor i have dky Q somthing is diferent uhd or hdr poor and on meyflix everything is in hd as in the past use to mention hdr uhd 4 K etc
now its just hd
Re: Picture from sky Q not the same no uhd or hdr
now its just hd
hi @Harry221
check that the resolution has not switched back to 1080
Home - Settings - Setup - Audio Visual -Picture Resolution
Avatar for Harry221
Checked all that thank you
nothing worked Sky sending someone soon
tks
This message was authored by: Mister_Dalek
tks
Did you get your Q box changed recently? It's possible you have been given an older non-UHD capable box as a replacement. There are various versions of Q box in circulation and Sky customer services and Sky engineers often don't know the difference between them or check whether they are replacing like for like.
