This discussion topic has been answered Discussion topic: Wall mounting q box
Message posted on 23 Jan 2024 06:41 AM
Thinking of wall mounting tv. Can I wall mount sky q box behind tv. Will remote still work?
Message posted on 23 Jan 2024 11:04 AM
@Suzyq1 wrote:Hi, thanks for your response. We are trying to find ways of mounting our TV on wall bracket and having no cables visible for soundbar and sky q box. Can the q box be located elsewhere in the room and be connected via WiFi as opposed to cables?
No. Not without a lot of extra kit at considerable expense.
Message posted on 23 Jan 2024 07:35 AM - last edited: 23 Jan 2024 07:36 AM
Re: Wall mounting q box
Hi @Suzyq1 Mounting the SKYQ main box behind a TV is not advisable apart from issues from heat trasfer, the box is designed to work horizontaly.
The Mini box can be mounted behind a TV, but still needs some ventilation as the box does get warm in normal use, the bluetooth remote should still work.
Message posted on 23 Jan 2024 10:59 AM
Message posted on 23 Jan 2024 11:22 AM
Not really: although 'HDMI wireless senders' are a thing, they are notoriously unreliable.
