4
This discussion topic has been answered Discussion topic: Wall mounting q box
This message was authored by: Suzyq1
Wall mounting q box
Thinking of wall mounting  tv. Can I wall mount sky q box behind tv. Will remote still work?
This message was authored by: Jones_The_Cat Answer
Re: Wall mounting q box
@Suzyq1 wrote:
Hi, thanks for your response.  We are trying to find ways of mounting our TV on wall bracket  and having no cables visible for soundbar and sky q box. Can the q box be located elsewhere in the room and be connected via WiFi as opposed to cables?
No. Not without a lot of extra kit at considerable expense.
Hi @Suzyq1 Mounting the SKYQ main box behind a TV  is not advisable apart from issues from heat trasfer, the box is designed to work horizontaly.
The Mini box can be mounted behind a TV, but still needs some ventilation as the box does get warm in normal use, the bluetooth remote should still work.
Avatar for Suzyq1
Not really: although 'HDMI wireless senders' are a thing, they are notoriously unreliable.
Answered - Go to Answer
