Discussion topic: Waiting for tv schedule
Message posted on 01 Dec 2024 05:44 PM
To guide says waiting for tv schedule
Message posted on 01 Dec 2024 06:07 PM
Re: Waiting for tv schedule
min is stuck on waiting for programme to load
Message posted on 01 Dec 2024 06:15 PM
Message posted on 01 Dec 2024 06:23 PM
Seems like an issue with sky streaming
Connected via ethernet on a 900 MB fibre connection
Message posted on 01 Dec 2024 06:24 PM
Netflix seems to be working okay
Message posted on 01 Dec 2024 06:57 PM
I am stuck on please wait for your programme to load and then goes to main page again and says technical fault on all channels
Message posted on 01 Dec 2024 07:10 PM
I had to push standby on the control, turn the sky box off for a min then back on and all working now
Message posted on 01 Dec 2024 07:46 PM
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Message posted on 01 Dec 2024 08:12 PM
Thanks everyone, the reboot worked. Don't know why I hadn't thought of that.
Message posted on 10 Nov 2025 12:18 PM
Having problem with seeing TV schedule
Message posted on 10 Nov 2025 12:19 PM
Have you rebooted the box as suggested above?
