Discussion topic: Waiting for TV Schedule…
Message posted on 19 Aug 2023 06:56 AM
LAN fibre connection no internet issues
sigmnal 60
Quaulity 90
i know how to fix it but comes back frequently enough to cheese me off.
Message posted on 19 Aug 2023 08:02 AM
Re: Waiting for TV Schedule…
Hi @ATC7 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?.
Message posted on 19 Aug 2023 08:09 AM
Thanks for trying to help , as I said in my post I know how to fix it but it keeps coming back I want Sky to solve this ongoing issue
Message posted on 19 Aug 2023 08:16 AM
If the advice from @Quoman7 doesn't help long term, you will need to contact Sky if you want them to solve it.
Message posted on 19 Aug 2023 10:29 AM
Thanks and agreed but Sky said to go MySky app which sent me here , just need escalating, I am not the the only one with this issue . Sky do not even list it as a known issue.
