Discussion topic: WPS not working
Message posted on ‎03 Jan 2024 07:03 PM
WPS not working
Connection issues, called sky, loads of troubleshooting, reset everything etc, sent me new Q box. Now seems worse, when option is displayed to choose a sky broadband hib to connect to, I can't even click on it. Hold down WPS button, doesn't flash. It's as if I can't select the option at all. Doesn't feel like it's even set up to take a WiFi signal?
Message posted on ‎03 Jan 2024 07:09 PM
Re: WPS not working
Hi @Jd100
If you are carrying out a Network reset on your Q box it asks you to press the WPS on the Sky Q hub. Make sure that you are not pressing the hub reset button. The Q hubWPS button is shown below.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
As you are on Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Message posted on ‎03 Jan 2024 07:15 PM
Re: WPS not working
Tried all of the above and no luck, won't even allow me to select 'connec to sky broadband wifi'
Message posted on ‎03 Jan 2024 07:33 PM
Re: WPS not working
Hi @Jd100
First try rebooting your main Q box.
Then try completly completely resetting your remote.
