Discussion topic: WPS connectivity issue
This message was authored by: Munz_Family
Internet connectivity issue despite signal strength 90 and quality 90. WPS reboot not working!
Re: WPS connectivity issue
Your signal strength and quality is referring to your satellite signal from the dish and has no relevance to your internet.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Munz_Family
Is there a reason why my Sky provided internet router keeps on losing connection with my Sky Q box?
And how can I check my Sky router signal strength and reliability, if that is the issue?
Awaiting an answer.
@Munz_Family wrote:
Awaiting an answer.
@Munz_Family you do realise this is a customer to customer forum where customers help each other and not Sky customer services
What Sky router do you have black or white ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi. It's black - under a year old.
TIA
Hi @Munz_Family
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
