Discussion topic: No internet connection
This message was authored by: Dennis33
I have turned off both sky box and internet hub and reset the connection, but still stating no connection. I have run a diagnostics check on my sky app and there is no issues. Cannot understand why it won't connect to the internet
Re: No internet connection
Hi @Dennis33
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
