Discussion topic: Volume set up
This message was authored by: Rivky+marquez
Volume set up
Only the volume not working
Re: Volume set up
You may have to explain in a little more detail as our crystal ball is on the blink.
Have you paired your remote to the TV?  Tried all the codes for the make?
Re: Volume set up
@Rivky+marquez Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
