Discussion topic: Volume level fluctuations on UHD broadcasts
This message was authored by: Super+Anthony
Re: Volume level fluctuations on UHD broadcasts
For me it seems to happen on other channels as well
(Please Note: I am Neurodivergent )
Avatar for DPT79
This message was authored by: DPT79
@lettice
Sorry I keep realising there were other things you asked me!
In terms of the frequency of the volume level fluctuating it will do it maybe 2 or 3, perhaps 4 times during a 3-4  ish  hour window whilst watching the F1 pre-amble, race and post-amble.
It is quite a marked chenge, i will have to adjust the AVR volume by 4-5 steps to get it back to the same level.
thanks!
Thanks @DPT79
Have enough info for now, I will pass on to Sky tomorrow for you and flag this post.
Please though on your recording of hdr and if poss, the live hdr cricket 'rain or shine 😀 at Edbaston tomorrow' try my suggestion to see if it helps. May not be a complete cure, but report if it's reducing the problem somewhat..
Avatar for DPT79
Thanks very much and will do.
I also changed to the setting from DD+ to DD and it didn't do it again after that point, although not long enough to really judge if it is resolved.
@lettice Thank you for all your help. I was watching most of the cricket and the sound was very low. Hopefully with your help Sky can look into this. I don't fully understand how the levels can change so often
This message was authored by: EANTC01
I have a Samsung 75" tv running of one of my three pucks and I am experiencing fluctuations in volume whilst watching football in UHD. The volume keeps going up for short periods and then drops back to normal. I know the TV or Skyglass - I can't remember which - has the facility to increase the volume if the ambient noise in the room increases, but it's doing it without the room noise level going up!
