Discussion topic: Volume level fluctuations on UHD broadcasts
Message posted on 17 Jun 2023 03:01 PM
I'm experiencing a persistent issue whereby the volume level fluctuates when watching an UHD broadcast. I've only noticed it on sports because that is what I tend to watch in UHD. I'm not talking about when changing channels or between the programme content and adverts (although that is extremely annoying), I'm talking about the volume level noticeably stepping up or down in the midst of the programme content. I've noticed this on different channels (both F1 and Cricket) and over a protracted period of time.
Many thanks
Dan
Message posted on 17 Jun 2023 03:09 PM
Re: Volume level fluctuations on UHD broadcasts
I have noticed the same thing but not just on the UHD channel. Even though I have not changed the volume, it's sometimes louder or quieter the next day
Message posted on 18 Jun 2023 06:53 PM
I'm watching F1 right now and it's doing it. I've noticed a further detail as well: the volume of the programme fluctuates up and down but the adverts stay the same. So when the programme volume has dipped and I turn it up to compensate, when the adverts come on they are even louder by comparison.
Message posted on 18 Jun 2023 06:57 PM
Same with me. I don't understand. Maybe someone at Sky could report to this link
Message posted on 18 Jun 2023 07:01 PM - last edited: 18 Jun 2023 07:04 PM
@DPT79 Do you use a soundbar of hifi, or just the TV speakers? If the latter check the audio options in the Sky Q menu is set to normal not DD. This may help with the sound levels.
These channels tend to broadcast with 5.1 audio which doesn't play well with a normal TV setup when the audio on the Q box is left in DD mode.
Message posted on 18 Jun 2023 07:03 PM
Sound bar
This morning I did software update, even though there was not one and the sound seemed louder
Message posted on 18 Jun 2023 07:21 PM
@DPT79 wrote:I'm watching F1 right now and it's doing it. I've noticed a further detail as well: the volume of the programme fluctuates up and down but the adverts stay the same. So when the programme volume has dipped and I turn it up to compensate, when the adverts come on they are even louder by comparison.
Not noticing this Myself on F1 uhd, have been changing my sound sources from tv to sound bar and switching tv to one with an integrated sound bar option.
Im using Sky q box av settings of Dolby Digital Plus, you may want to try using just the Dolby Digital option, that can help in some setups for sound glitches.
Also, for some tv sound setup glitches a switch to another tv source for a count of ten or putting your Sky q box into standby, for about ten seconds and back on, can cure those random annoying glitches that I think at some point most of us have at some point across differing channels.
If you record the uhd feed, does it also do it there?
Message posted on 18 Jun 2023 07:34 PM
Thank you for all that. Have flicked as you suggested but no difference on Dolby digital. I have gone back to DD plus
Message posted on 18 Jun 2023 08:18 PM
HI - thank you. I'm using a 5.1 set-up with the Sky Q box plugged in to an AV amp, so DD ought not to be causing any issues.
Message posted on 18 Jun 2023 08:26 PM
thank you for this. It does it on recordings as well. I've tried all sorts of soft and hard reboots of the box, but the issue is persistent.
I do have it on DD+ right now, so I'll try DD, even though it's still surely a box or broadcast issue as DD+ ought to be fine into an AVR.
Message posted on 18 Jun 2023 08:27 PM - last edited: 18 Jun 2023 08:27 PM
Same. My 5:1 sound bar is plugged into the TV though the e-arc which I was advised is the best way. I then got the Sky box plugged into TV
Message posted on 18 Jun 2023 08:46 PM
@DPT79 wrote:thank you for this. It does it on recordings as well. I've tried all sorts of soft and hard reboots of the box, but the issue is persistent.
From what I've seen on multiple setups a reboot of the Sky q box often makes no difference in these sound glitches, but the tv source change or just Sky drop to standby seems to help, especially when it's more random.
Think if it was a broadcast issue, we possibly would all be getting it
If you want to list your tv model, audio devices and Sky q box in some detail, plus the channels and rough amount of times a day/ hour etc you get this I will pass on to our closed forum for a possible technical check with Sky.
Sky do work closely at times to solve Sky device problems with the major tv manufacturers and the like try to resolve issues.
Message posted on 18 Jun 2023 08:48 PM
I think you might be right. I just did it and seems to be better!!!
Message posted on 18 Jun 2023 09:02 PM
Thanks again. I'll try the standby and tv source change.
TV is an LG C9, AVR is an Anthem MRX520. Sky Q box hardware version is 32B240. The sky box goes through the AVR.
Message posted on 18 Jun 2023 09:05 PM
in terms of of times, channels etc. I've only noticed it on UHD channels and sports. I experience it both live and recorded on F1 and I watch every race, so that gives a good idea as to when. It was certainly doing it last year as well as this, up to and including today. I also watch cricket from time to time and it was doing it both yesterday and today on the Cricket channel UHD.
Thanks again.
