Discussion topic: Volume control
This message was authored by: Pablus
Volume control
When l plug the wired headphones into my TV the volume is too high.l turned it down to zero on the sky q box and it's still too loud.Can anyone help?
Re: Volume control
Hi @Pablus  The Sky Q box does not have any volume controls. If you are using the Sky Remote to turn down the volume, it is only turning down your TV (or soundbar) volume exactly the same as using the TV (or soundbar) remote. You need to refer to your TV manual to see how to adjust the headphone volume output.
