Discussion topic: My sky wint come on?
This message was authored by: Sexylegs22
Message posted on 29 Apr 2024 05:49 PM
Turned my TV on and it usual comes on with my sky remote but it's saying check signal which I have done.
Find out more
Message posted on 29 Apr 2024 06:06 PM
Re: My sky wint come on?
Hi @Sexylegs22
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
