Discussion topic: Volume control
Message posted on 09 Sep 2023 04:50 PM
Volume control
We are having issues with our SkyQ remote
we are unable to turn the volume up and down or turn the tv off with the remote.
this has randomly happened.
We have tried re pairing the remote.
We can change the channel etc.
Message posted on 09 Sep 2023 05:06 PM
Re: Volume control
hi @SamT
Looks like your remote is not correctly paired to your brand and model TV set.
Try new batteries in the remote and Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 09 Sep 2023 05:10 PM
Re: Volume control
Thank you,
thay doesn't seem to be working either.
very odd
Message posted on 09 Sep 2023 09:35 PM
Re: Volume control
